Badly Installed Patio Door Causing Leak - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 02:22 PM   #1
Rewards Points: 16
Badly installed patio door causing leak
I recently bought a house with many problems. One of those is a leaking patio door (Leaks in the wall causing mold in the basement wall below). The water appears to get in from the exposed horizontal brickwork. I believe this should have been covered with flashing and an aluminum or pvc sill extension when the patio door was installed.
I dont want to install a new patio door. What can I do until then?
bighak is offline   Reply With Quote
Old 12-27-2012, 02:34 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,076
Seal it with a good penetrating mortar seal and seal the gap in the threshold and the brick.
If that doesn't do it, you can cover it with coil stock if you want.
Old 12-27-2012, 02:47 PM   #3
kwikfishron's Avatar
Rewards Points: 212
Looks like the trim needs caulked too.
kwikfishron is online now   Reply With Quote
Old 12-27-2012, 06:09 PM   #4
Rewards Points: 16
Thanks for the tip! Penetrating mortar sealer seems like an easy solution to this problem. I'll apply that and redo the caulking.
Old 12-27-2012, 06:12 PM   #5
Give them time to dry in between.
Siloxane is what we have used previously and seems to work well.
Old 12-27-2012, 06:56 PM   #6
Rewards Points: 212
Is this a brick house with a deck attached to it or is that just brick filling in the gap? Why is there brick missing on the right side under the trim?
A picture standing back showing the entire area would help, also another showing the ledger under the deck and how it’s attached to the house.
Old 12-27-2012, 07:32 PM   #7
Rewards Points: 16
A picture standing back showing the entire area would help, also another showing the rim joist under the deck and how itís attached to the house.
Brick house with a deck. There is a brick but it's dirty.
Old 12-27-2012, 08:27 PM   #8
+1 to Ron's question.
How is the ledger attached to the home? They are notorious leakers when done incorrectly.
Old 12-28-2012, 12:58 PM   #9
Rewards Points: 13,300
All the sealing and flashing needed to be done under the door, not just some stuff smeared on the outside.
http://jamsill.com/
With the deck being that close to the threshold there's always going to be splash back causing an issue.
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 02:41 PM
Badly Installed aluminum double hung windows in a rental Mrnagrom Remodeling 3 01-07-2009 02:31 AM
New cememt patio stained by wet leaves Bhoward Landscaping & Lawn Care 7 12-03-2008 12:35 PM
10-12' wide patio door installed gregoryedgar Building & Construction 2 06-02-2006 07:57 AM
