Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-11-2012, 01:05 PM   #1
subati's Avatar
Automatic swing door opener
Hi,
I am looking for some recommendation for an automatic swing door opener. We own a laundromat and we need to pull open a door in the morning and close it shut at night. The door currently has a automatic door lock. Since the door will be operated only two times per day, I don't want to spend a fortune on it. One of the products I came across was Skylink DM 150. However, this one can't leave the door open for the entire day.
Are there any other products out there that can achieve this?
Sudheer
FreshO Laundry
subati is offline   Reply With Quote
Old 09-13-2012, 09:37 AM   #2
REDRUM's Avatar
COUPLE OF OPTIONS
A) get a manual door closer with a "hold open function" these can be found under 100$
B) surface mounted auto door operator
http://www.edsdoors.com/horton/drawi...ger/4056d1.pdf
unit cost around 1500$ + electric power
this unit can be programmed to hold open then push to close.
REDRUM is offline   Reply With Quote
Any thoughts on hanging a foot pedal on porch swing? tabatt07 General Discussion 1 07-25-2012 05:54 PM
main burners cut out/ no automatic vent damper? Shevek HVAC 6 11-14-2011 01:33 AM
Will this vertical-posts Swing set plan work? diy_in_md Building & Construction 14 10-15-2011 11:06 PM
I bought a New Front Door, but wrong swing... Fisher252 Windows and Doors 8 06-09-2011 11:58 AM
Porch Swing nikeman Building & Construction 21 03-07-2011 08:15 PM
