Automatic Garage Door Issues - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 10:34 PM   #1
I have an older, somewhat rickety wood garage door that has a newer automatic closer attached to it. When the door is in the open position, it only moves about six inches forward before it stalls for a brief second then retracts to the fully open position. If I manually put the door down and then raise it up with the opener, it has no problem.
The automatic opener (belt driven) is not mounted in the center - it is off to the far right. The track on that side is not exactly straight - it widens away from the door. There are sensors, but they appear to be lined up correctly. I wasn't sure if there is a way to check them though. The rollers seem to be OK as they pretty much stay on the track. I did have to add a newer roller on one side.
Anybody have any thoughts on this?
Thanks!
sobro is offline   Reply With Quote
Old 08-02-2012, 05:45 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Paging Mike.....
Check the closing tension, travel, and sensor alignment.
Old 08-02-2012, 08:01 AM   #3
Rewards Points: 6,652
My question would by why is the drive off to the far right? If the track is not straight, or it is pulling more on that one side yes it could cause problems. My guess is that because the drive is to the right, is why the track is all crooked. Post pictures so that people can get a better idea with what you are dealing with.
Old 08-02-2012, 08:57 AM   #4
ok - I can post pics of needed.
How do I align the sensors?
Also, if it's the travel, how do I adjust this?
Thanks!
Old 08-02-2012, 10:11 PM   #5
firehawkmph's Avatar
Rewards Points: 1,864
Post some pics Sobro. Also, what kind of opener do you have?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
Garage floor Tomperro Building & Construction 3 07-17-2011 11:37 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 01:50 PM
