Attaching Trim To Vinyl Jamb Extension - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 11:56 PM   #1
Rewards Points: 518
Attaching trim to vinyl jamb extension
I have two new windows with vinyl jamb extensions that I need to attach MDF casing to. How do I attach it closest to the reveal for a snug fit? Looking at other windows in my home it looks like the installers used a pneumatic nailer and just nailed into the vinyl jamb extensions??
n0c7 is offline   Reply With Quote
Old 04-11-2013, 06:36 AM   #2
DIY staff
Rewards Points: 7,174
We need more info---Is the vinyl extender solid or hollow? How deep? Is there any chance of the nails hitting the operating part of the window?
Old 04-11-2013, 09:26 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
a lot of times a brad nailer (pinner)is used along the edge where the trim meets the extension and a heavier nail is used to hold the trim to the wall or/and some adhesive used as well
hand drive is offline   Reply With Quote
Old 04-11-2013, 09:29 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Picture...
Old 04-11-2013, 10:31 AM   #5
Rewards Points: 518
Hollow, deep enough that nails won't hit or affect operation.
After wiggling the casings on my other windows it looks like the installers just pinned the casings into the vinyl. I'm thinking of using some adhesive with brad nails into the jamb extension and finish nails into the framing as mentioned.
I can take some pictures tonight.
Old 04-11-2013, 01:57 PM   #6
Rewards Points: 880
This will work just fine.
I was suggesting pictures because they are usually worth a thousand words.
Old 04-12-2013, 12:52 AM   #7
Rewards Points: 518
Here are my existing windows:
Here are my new windows with jamb extensions:
Old 04-12-2013, 07:58 AM   #8
AHH, SPANS!!!
the side you are showing is the outside, do not nail into hollow jamb extensions on the outside of structure. make sure window is shimmed correctly and only nail trim to solid wood surrounding window and use OSI Quad caulk to back caulk the trim where it goes over the extension. it is bad enough that they are hollow(bad theraml properties), adding holes in them is even worse....
Old 04-12-2013, 11:28 AM   #9
Rewards Points: 518
That's the interior shot. The nail flange is on the outside. It's two windows laying against each other - an optical illusion
Adding vinyl trim to existing windows rismith1 Windows and Doors 1 12-11-2011 04:47 PM
Sidelight - Cannot find vinyl trim lrichards Building & Construction 2 08-28-2008 05:42 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
