Attaching Exterior Door Pediment - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 01:26 PM   #1
attaching exterior door pediment
I have an exterior door with 2 sidelights on either side which is actually one piece. The house is wood siding and no porch cover, just a stoop, but very traditional. I am looking to purchase a broken pediment for above the door with the attached sidelights. The total width of this is 63". I also need to cover some metal flashing that is between top of door trim and the trim to be replaced. Where do I begin?
Jennifer 123 is offline   Reply With Quote
Old 05-30-2011, 02:15 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
what kind of trim are you thinking? wood or a synthetic product?
which ever for the exposed location your talking about you will need to remove some siding and add flashing not cover it
Tom Struble is offline   Reply With Quote
Old 05-30-2011, 07:56 PM   #3
Custom Home Builder
A pic would help.
thomasjmarino is offline   Reply With Quote
Old 06-08-2011, 11:31 AM   #4
www.doors4home.com
jason.r's Avatar
I would definitely check with your local lumber yard as any broken doors or accessories would be "in-stock". This would be a good place to start.
Outside of that contact a local handyman/contractor for any advise with what you are looking for. The deminsions are not uncommon and you are sure to find what you are looking for - a contractor may even quote you for building a new pediment.
Good Luck!
Jason
jason.r is offline   Reply With Quote
Old 06-08-2011, 06:36 PM   #5
no Jason she wants a broken pediment,not a broke pediment
http://en.mimi.hu/architecture/broken_pediment.html
Attaching Cabinetry to Concrete Floor bchcadmin Remodeling 2 03-30-2010 06:21 PM
Garage storage, attaching to engineered beams jdcook72 General DIY Discussions 6 06-16-2009 11:01 PM
Attaching CMU partition walls? figs Building & Construction 14 06-15-2009 04:02 PM
Attaching Drywall to 4" of Rigid Foam PerpetuallyRepairing Drywall & Plaster 9 02-19-2009 05:24 PM
Attaching Studs to Concrete/Which way mjkpainting Carpentry 17 12-30-2008 10:02 AM
