Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-18-2012, 06:03 AM   #1
-_-
Arched window glass replacement in front door
Like most of my house projects, I was fixing one thing and broke another...
Anyway, we have a front door (circa 1935) with an arched window. It separated into 4 panes by moulding. How do I remove the moulding to replace the glass? Did they usually cut small individual panes, or is it one big half-circle of glass?
-_- is offline   Reply With Quote
Old 09-18-2012, 09:06 AM   #2
Exterior Construction
Windows on Wash's Avatar
Picture of the inside and outside (up close) will give us what we need to know in order to make recommendations.
Old 09-21-2012, 11:29 PM   #3
-_-
Sorry I didn't get any pictures.
I scored the seam of the moulding with a razor and then pried it up with a putty knife. Used a second knife to push it away from the glass. It was held on with small brads.
They don't sell plate glass for doors anymore, I had to use safety glass. Turns out that is a little thicker, so I used a Dremel tool to trim the moulding.
Anyway, I'm all set now.
Found a decent video about a similar problem:
http://www.youtube.com/watch?v=u6FHjnmDjKQ
Old 09-22-2012, 11:06 AM   #4
The will almost definitely be single panes.
A photo would be useful, but did you fix it already?
It's going to be difficult to cut safety glass, don't you need it to be pre-cut?
Gissle is offline   Reply With Quote
Replacing garage door with wall containing window and/or door diyer101 Remodeling 9 11-23-2012 08:47 PM
Door glass framing and glass replacement housegsx Windows and Doors 2 12-15-2011 05:52 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Where to get a replacement frame for a sliding glass door cowboyway2112 Building & Construction 1 04-08-2010 08:26 PM
front door jam replacement a_theater_god Remodeling 3 07-30-2006 11:35 PM
