Anyone Know How To Mount Storms In These Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 04:51 PM   #1
Anyone know how to mount storms in these windows?
Have a 1908 brick house with wooden sash windows that I am restoring. The brick molding around the windows is a bullnose profile (see photo). Has anyone seen how they fit a wood storm into these. I do not have original storms and am not even sure that there were any. I want to have a tight fitting wood storm along the edges, but trying to cut a reverse curve profile seems ridiculous especially if I want to adjust the width for a close fit. I am thinking of machining a rabbet into the back of the storm and have the lip extend out to the molding (see drawing). Then the next question is how to secure it?
frtools is offline   Reply With Quote
Old 06-28-2013, 06:03 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,744
Very unlikely that they window opening is square enough to be able to mount that storm that perfectly to that small a lip.
Have you pulled a section of the brickmould?
Old 06-28-2013, 08:16 PM   #3
Rewards Points: 13,228
In love with that style molding for some reason?
If not change to real brick mold.
Then the storms would work.
Most of the trims going to get covered anyway.
Old 07-10-2013, 08:10 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
I just trimmed out all the dormers on an historical house with that 1 1/2" quarter round. had it milled from PT dry lumber so the stuff should last forever.
on topic and related to original postrs storm door issue- not sure how the storm will mount to it though when it's used as brickmold around door...
hand drive is offline   Reply With Quote
Old 07-10-2013, 08:33 AM   #5
Your going to put pressure treated wood in direct contact with aluminum?
For one thing the finish on the frames will start to bubble off.
Pressure treatment does not go all the way through the wood, milling off the outer layer may have left the wood unprotected if to much was taken off.
DIY Camera Mount divedaddy03 Tools 0 04-06-2013 02:05 PM
Windows? Erickp40 Windows and Doors 5 11-17-2011 11:53 AM
Replacement windows - flashing question smoenra General DIY Discussions 0 11-02-2011 12:07 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
