Anyone ever seen two windows not double pane?
Fix it, dead air space is a good insulator, however, leaky windows allow that air to move around between the two panels. You WILL be able to realize some significant gains by replacing those windows, but not even so much for that reason, but in sunny southern cal, low-e glass will do wonders for you. Look for a low SHGC, like .2 or lower.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
