Anyone Ever Installed A Fresh Install Deadbolt On A Steel Hollow Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 10:04 PM   #1
Rewards Points: 48
Anyone ever installed a fresh install deadbolt on a steel hollow door?
i got a metal hollow door filled with honeycomb cardboard as a core down in the basement storage and i want to add more protection to it. It came with one bore hole but i want to add a deadbolt. My concern is that is it possible? this metal hollow door has no wood near the borehole section and is only welded 2 piece of metal for the cross bore for that bore hole only. If i made a new bore hole for a deadbolt is there any issue i will run in to? Like not being able to tighten the deadbolt to the door as it will wrap the door due to the door being hollow? Do i need to fill it with something and if so is there a product cause i can't find anything about it? or am i just thinking too much. Thank you.
bklynsoulja is offline   Reply With Quote
Old 12-26-2013, 11:19 PM   #2
Rewards Points: 13,752
Yup, thinking to much.
Use a bimetal hole saw, drill through one side and only allow the pilot bit to come through the other side then stop. (do not all the way through both sides.)
Finish by boring the other hole from the other side of the door.
Old 12-27-2013, 09:01 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Before you even drill holes in the door, be certain that you can mount the bolt unit in the edge. If there is no solid blocking inside the door, there will be nothing to stop the bolt from flopping around. Also without blocking, the door will crush as you tighten the cylinder screws. All is not lost. Look inside the existing bore to try to learn how the door is constructed. Sometimes there is wood blocking in the lock area. Sometimes there is a wood strip along the edge to carry the bolt unit. In that case, cut some wood blocks that you can wedge inside the door to stop it from collapsing. If nothing else works, you can use a mounting channel like this:
http://www.don-jo.com/product-lines/...rap-around-10/
You can probably get one of these from a local locksmith or maybe a lumber yard.
Old 12-28-2013, 08:22 PM   #4
Rewards Points: 48
hey guys im in a situation, the drive in latch adapter that came with it does not fit snug, strange because i used a 1 inch hole saw for the cross bore hole and apparently it now alittle bigger that it wont fit snug into it but just passes through. how can i resolve this? i really appreciate the help.
Door Install Help benleef Windows and Doors 7 01-03-2013 07:12 PM
New Construction - 32" Exterior Garge Door Install yamsicle Windows and Doors 9 09-25-2012 06:06 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Stanley Pocket door hardware install P14ZZ4 Carpentry 15 11-03-2010 10:06 AM
How to install wood screen door and exterior steel door orange Remodeling 2 07-16-2010 12:00 PM
