Antique Double-Hung Windows Missing Pulley Weights - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 02:46 PM   #16
Mold!! Let's kill it!
Rewards Points: 2,012
Wow. I've seen so many of these that I just assumed they were common everywhere. In the link below is a sketch. About halfway down is a drawing of the access door to get to the weight.
Also to the OP. Because the sash have grooves cut into the sides does not mean they were weight balanced. Spiral spring balanced sash had grooves cut into them. Do a google search for "Unique Sash Balance"
http://www.do-it-yourself-help.com/w...rd_repair.html
The Following User Says Thank You to Maintenance 6 For This Useful Post:
kwikfishron (08-01-2011)
Old 08-03-2011, 10:04 PM   #17
Rewards Points: 77
N00B, I feel your pain. Most of our windows are shut in multiple forms, whether painted and screwed, glued and painted, siliconed and screwed, or wedged and glued. The previous owners just weren't handy at all... and were rather silly in their deferred maintenance.
OurHouse is offline   Reply With Quote
Old 08-06-2011, 09:22 PM   #18
i have been working on a similar project since i bought my current home. I lucked out and found that all of my unused sash weights were stored at the bottom of the pockets. Also, i found replacement sash weight cord at my local ace hardware.
Good luck!
1910NE is offline   Reply With Quote
Old 08-06-2011, 10:46 PM   #19
Rewards Points: 77
N00B, how's it going? I went today to help a friend on hers because she has more experience with the window work. She is doing those metal channel additions. Should I get the source info for you? She said she only found one place sold them, but they're only 75cents per foot or so.
Old 08-15-2011, 05:46 AM   #20
Maryland
We've replaced the old wood sash in our home with replacement windows. Have about 14 windows worth of pulleys/cast iron weights. Send me a PM if you'd be interested in them.
Pittsville is offline   Reply With Quote
How are atrium double hung windows? bmf5150 Building & Construction 2 01-05-2008 01:50 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
Double Paned Windows cambece Remodeling 5 10-04-2006 03:31 PM
Double Glazed Windows Black Sealing Strip hansi General DIY Discussions 2 09-08-2005 04:05 AM
how to clean double pain windows DIYER33 General DIY Discussions 3 04-12-2005 11:53 AM
