Anderson 'A' Series Windows. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 08:46 AM   #1
House & me same age
Anderson 'A' series windows.
Anderson 'A' series double hung window problem.
***Moderator edited*** http://www.diychatroom.com/f2/how-si...ct-site-37099/
Anderson 'A' series windows.-unlocked.jpg   Anderson 'A' series windows.-locked.jpg
razzorm is offline   Reply With Quote
Old 12-12-2011, 09:03 AM   #2
Where the windows vinyl, aluminum or wood? Just curious.
LMPD is offline   Reply With Quote
The Following User Says Thank You to LMPD For This Useful Post:
razzorm (12-12-2011)
Old 12-12-2011, 09:38 AM   #3
House & me same age
Window type
Window is vinyl new construction.
Old 12-12-2011, 04:31 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
While Andersen makes a decent wood window when you get into their 400 series, their vinyl and replacement windows (RBA) are just average if not below.
Sorry to hear of your issues.
Old 12-12-2011, 04:48 PM   #5
Rewards Points: 14,312
One of the many reasons I will not deal with Anderson or Pella.
Old 12-12-2011, 06:28 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
A- series is all Fiberex not vinyl
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (12-12-2011)
Old 12-12-2011, 09:24 PM   #7
+1
Fibrex (albeit mostly vinyl by constitution although they trash vinyl).
Old 12-13-2011, 11:01 AM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Razz, open the upper and lower sash so that you can see about 1/4" of light on each. Are those reveals even all the way across?
It is standard procedures for most if not all manufacturers to ship the windows unlocked. This usually does make for a harder lock until the seals break-in, however it should improve relatively quickly.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 12-13-2011, 03:53 PM   #9
Rewards Points: 109
Andersen A series is pultruded fiberglass not fibrex except for the jamb liners.
100 series is fibrex
oberon is offline   Reply With Quote
The Following User Says Thank You to oberon For This Useful Post:
Tom Struble (12-13-2011)
Old 12-13-2011, 08:55 PM   #10
thanks for straightening me out Oberon
Old 12-14-2011, 06:59 AM   #11
Rewards Points: 2,240
What it looks like from your 2nd picture - the latch-side, of the sash-lock -
is not installed in the right place.
(Too close to the upper sash)
This can happen with any manufacturer - dozens.
Remove the latch/lever side -
Fill the existing screw holes -
Let the filler set up -
Close the window -
Position the lever and engage the lock -
Carefully mark the position of the new screw-holes (Sharp, center-punch)
Pre-drill the new screw holes (Carefully! - with a drill size smaller than the
thickness of the screws -do not drill too deep!) -
Reinstall the latch.
Do not over-tighten the screws!!!!
We've had to do this way too many times!!!
If you're not comfortable doing this - find a "Window and Door", person
in your area and have them look at it.
(Probably, don't mention this to "Customer Service"!!!)
(Andersen - "Customer Service" ????!!!) Huh!!!???
This problem is not uncommon!
rossfingal
rossfingal is offline   Reply With Quote
Old 12-14-2011, 01:10 PM   #12
House & me same age
Moving the sash lock
To Rossfingal
Yours is a good sugestion but--
The sash lock when turned the oposite way of locking the window pulls in the tabs on the outside of the sash that allows the lower sash to tilt in for cleaning.
I have removed the sash lock screws and there is no movement allowed in the sash lock.
I like the window overall but this issue with thier top line window just is not satisfactory to me.
I need 12 more windows but I don't think they will be Anderson.
Anderson customer service is a joke. They submit my concerns to the area Anderson rep. who tells them it is a customer issue and cancels the service call.
Old 12-14-2011, 10:37 PM   #13
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Razz, what is the answer to my previous question?:
"Razz, open the upper and lower sash so that you can see about 1/4" of light on each. Are those reveals even all the way across?"
Please post pics if possible, as it will either confirm your strong, negative opinions on the product, or expose a poor installation.
www.HomeSealed.com
Old 12-15-2011, 11:48 AM   #14
House & me same age
To HomeSealed
Added pictures to show that window is square, level and plumb.
Anderson 'A' series windows.-001.jpg   Anderson 'A' series windows.-002.jpg   Anderson 'A' series windows.-003.jpg
Old 12-15-2011, 12:32 PM   #15
A Series
My name is Wendy and I work at Andersen. I would liketo talk with you about your window situation. Please contact me @651-264-5963.
WendyG is offline   Reply With Quote
Anderson Casement Windows Problems I E S Windows and Doors 5 09-27-2014 03:27 PM
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
