Anderson French Door Lock Adjustment - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 03:56 PM   #1
anderson french door lock adjustment
I have 2008 Anderson French doors. The dead bolt lock is difficult to latch. Any suggestions?
fspitale is offline   Reply With Quote
Old 07-26-2012, 04:08 PM   #2
DIY staff
Rewards Points: 7,174
Can you figure out how to post a picture?
9 times out of 10 the operating door has sagged enough to cause the bolt to hit the bottom of the catch plate---
Take a picture showing the gap around the door--particularly at the top---
Also--extend the dead bolt with the door open and see if it is centered to the hole---
Then close the door and see if the two doors are flat to each other when closed--is one door good at the top but out at the bottom?
Issue with Anderson French Door. Help Please. dorothyolive Building & Construction 21 05-19-2014 10:18 AM
anderson french door is hard to shut. ricka1502 Windows and Doors 2 08-27-2011 10:48 AM
anderson french door hinge adjustment hhiland Windows and Doors 1 03-09-2011 06:43 AM
Anderson vs. Pella Exterior French Doors Beth R Building & Construction 5 11-10-2010 05:45 AM
Exterior Anderson French Doors baclarks Carpentry 4 01-25-2010 06:43 AM
