Anderson French Door Hinge Adjustment - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-08-2011, 11:45 AM   #1
anderson french door hinge adjustment
What is the process for adjusting the allen screws for the hinges on an in swing anderson french door? There are two allen screws on each of the 3 hinges. The door is tight on the bottom edge. The regular screws to the frame and to the door are all tight.
hhiland is offline   Reply With Quote
Old 03-09-2011, 06:43 AM   #2
If you don't have the instructions, don't try it. You should be able to find the instructions on Andersens website.
Issue with Anderson French Door. Help Please. dorothyolive Building & Construction 21 05-19-2014 10:18 AM
Anderson vs. Pella Exterior French Doors Beth R Building & Construction 5 11-10-2010 05:45 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
Exterior Anderson French Doors baclarks Carpentry 4 01-25-2010 06:43 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
