-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   anderson french door hinge adjustment (http://www.diychatroom.com/f104/anderson-french-door-hinge-adjustment-97674/)
hhiland 03-08-2011 12:45 PM
What is the process for adjusting the allen screws for the hinges on an in swing anderson french door? There are two allen screws on each of the 3 hinges. The door is tight on the bottom edge. The regular screws to the frame and to the door are all tight.
Just Bill 03-09-2011 07:43 AM
If you don't have the instructions, don't try it. You should be able to find the instructions on Andersens website.
