#1 |
anderson casement windows ... allow spiders to nest in frame
MY anderson windows are 20 years old and do not have a tight seal when you close them. This allows spiders/bugs to enter my home or
nest in the small area between the window and frame. I am not going to replace all my windows....what can i do to keep these pests from breeding/entering my home. Thanks... ac |
#2 |
Without a picture of the window not sure how anyone can suggest how to fix it.
#3 |
Windows & Remodeling
20 yr old casements are probably sagging. I don't believe that they have an adjustment cam like the newer models, but there are ways to get that sash back into place so that it seals properly. It involves re-locating some of the arms, etc, and really is not a DIY job.... Other than that, you could try some of that bug spray that is supposed to last for several months.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| has any one used andersen full frame replacement windows? | aticharger | Windows and Doors | 6 | 06-08-2012 12:32 PM |
| New flush fin windows, recessed stucco arch above old frame | thunder550 | Windows and Doors | 4 | 11-30-2011 08:48 AM |
| Anderson Casement Windows Problems | I E S | Building & Construction | 4 | 08-02-2011 06:35 PM |
| Replacing weatherstripping on Marvin wood casement windows | giger123 | Windows and Doors | 5 | 05-09-2011 07:50 AM |
| How do I install new windows? | RickT | Carpentry | 17 | 10-12-2006 07:06 PM |
