Anderson Bow Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 03:17 PM   #1
Anderson bow window
looking for a tip or two to finishing the exterior bottom of an Anderson bow window. also what do you recommend putting between head and seat boards prier to installing them ?
dimhomeimp@aol. is offline   Reply With Quote
Old 03-04-2012, 06:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Rigid foam if they aren't insulated.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (03-04-2012)
Old 03-04-2012, 06:27 PM   #3
Framing Contractor
Rewards Points: 100
We usually frame down with 2x8 and install rigid foam insulation. Then you can wrap the bottom with aluminum coil, azek, etc to finish it off. The underneath can be painted plywood, vinyl or aluminum soffit, or whatever.
sixeightten is offline   Reply With Quote
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Anderson Window profile Joe1. Building & Construction 1 08-14-2010 12:17 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
