Anderson 400 Series Trim Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 09:18 PM   #1
Anderson 400 series trim question
First off I would like to say hi and I am glad that I found this site as it seems to be very helpful. I have just installed a French patio door with I swing doors with a transom. I also got the exterior trim kit with a cornice. I also have the double sliding screen doors instead of the hinged doors. So the question is with these options is it possible to use the trim kit?
Kbryant is offline   Reply With Quote
Old 06-17-2012, 07:02 AM   #2
It seems because the screen door tracks stick out that the trim kit will not properly fit.
Old 06-17-2012, 08:35 AM   #3
DIY staff
Rewards Points: 7,174
Post a couple of pictures---PLEASE---
Old 06-17-2012, 09:13 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
are you talking about where the transom and door head meet?
Tom Struble is offline   Reply With Quote
Old 06-18-2012, 05:52 AM   #5
Yes where the transom and door head meet. Because of the screen tracks it pushes out the face of the door therefore not allowing the exterior trim to work the way it was designed which was to cover about 1/8 of the face. I'm going to give them a call to make sure that modifying the trim is what I am supposed to do. It looks pretty straight forward but I want to make sure.
Old 06-19-2012, 06:06 AM   #6
Ok sorry that I was never able to post pics but I got the answer that I was after and that was if you are using the extension jams for you screens then you will have to modify you trim kit. Not a big deal at all as all that is involved it cutting of the rabbit or the portion that was meant to overlap the face of the door.
The Following User Says Thank You to Kbryant For This Useful Post:
Tom Struble (06-19-2012)
window trim question blackestate Windows and Doors 22 09-21-2011 02:38 PM
Simple question - trim pipe or replace it? 3dartist Plumbing 3 05-24-2011 12:24 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
interior wood trim, surface preparation question copacetic Painting 3 04-25-2008 08:52 PM
oak trim, caulking and paint question THEBIGPUNN Painting 2 06-05-2006 10:28 PM
