Andersen Window Installation - RO - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 11:47 AM   #1
Thumb Banger
Rewards Points: 20
Andersen Window installation - RO
I'm putting in an double hung double wide 400 series window, new construction. The installation guide calls for a 3/4 inch plastic drywall corner guard as a back dam.
The window dimensions are 4' 8 7/8" x 6' 3 3/8".
My questions; I'm adding 3/4' to the width for the RO. If I add 3/4" to the height will that be enough to accommodate the 3/4" back dam? I don't think so and was going to add 1". There will also be the flashing to consider. I'm using that self sealing sill wrap, which is about 1/8", for flashing.
Also, do you think a 2x10 header will be sufficient? This is on the top floor, nothing above but the roof with a 12/4 pitch above this window, 12/8 in the front.
Another question that is perhaps for another thread. Would you tear off all this old house wrap? Time and money constraints make it difficult, but my gut tells me I should. It's run vertically. In some places there is 15# felt under it.
Thanks yet again for your time and suggestions!
scroff is offline   Reply With Quote
Old 08-23-2012, 12:50 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
I would leave house wrap over to the new opening. Is the window height 4'8 or 6' 3 ?
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
scroff (08-23-2012)
Old 08-23-2012, 03:36 PM   #3
Thumb Banger
Rewards Points: 20
Thanks, hand drive.
Ok. The height is 4'8. The width is 6'3, so I'm going with a 2x12 header and raising the window an inch or so. It will work out better than having 3" cripples.
So you think that old wrap will be ok? Or can I simply roll 30# felt over top of it?
Thanks again!
Existing Window Installation Earnie Windows and Doors 15 02-21-2012 01:04 PM
couple of window installation questions wengang1 Carpentry 5 10-19-2010 07:09 AM
Andersen Casement window stuck at top mark2741 Remodeling 10 04-23-2010 09:06 AM
Window installation advice Cossack Remodeling 7 04-16-2010 01:44 AM
Window installation - Best Practices Solar Dave Building & Construction 6 09-30-2008 01:20 PM
