Andersen Casement Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 05:38 PM   #1
Rewards Points: 193
I am writing with two questions about Andersen Casement Windows.
1.) I have these "crank" windows throughout my home. They are original windows to the home as built in 1980. The exterior color of the windows is terratone and, unfortunately, it is fading quite heavily in some areas. I've been thinking about buying the Terratone Color Aerosol Spray Paint to improve the look.
Does anyone have experience using this paint and/or can you speak to how effective this approach might be? I view the problem as entirely cosmetic. I realize this is a temporarily solution to the problem and the paint will also fade, but perhaps I'd get a couple of years out of it? I'd appreciate any input.
2.) One of my Andersen Casement windows has three pains and the middle pain has frosted over. Is it possible to simply replace the middle pain, or must the entire window be replaced?
Thank you for your time. I look forward to hearing from you.
aumanpj is offline   Reply With Quote
Old 07-23-2013, 06:03 PM   #2
Rewards Points: 13,712
Without being able to see it not sure how anyone here would know if the pane can just be replaced, need a picture.
What's the material your trying to paint?
Old 07-23-2013, 06:24 PM   #3
Rewards Points: 193
In this photo you can see the middle pain is frosted. I wonder if the middle pain can be replaced without replacing the entire window. You can also see at the bottom right corner of the trim, the window's terratone finish is discolored. I wonder if the terratone finish can be well refreshed using the Andersen paint identified in the original post.
Thank you for your attention, joecaption. I should have provided this photo in the original message.
Old 07-23-2013, 07:29 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
On glass: yes, generally it can be replaced by the panel.
On the paint: with some prep work , masking, etc, it would probably be serviceable as a "band aid" for a bit. Won't have the same quality of a factory finish obviously, but if you do a good job I'd think that it could look fine for a while.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 07-29-2013, 11:28 PM   #5
No, the middle pane cannot be replaced. You should buy a new sash.
The exterior has not faded, but will get a haze to it. Try cleaning it with a citrus cleaner. Or #0000 steel wool.
mknasa dad is offline   Reply With Quote
Old 07-30-2013, 08:29 AM   #6
firehawkmph's Avatar
Rewards Points: 1,884
+1
You should be able to get a replacement sash through any lumberyard that sells Andersen windows. The outsides of the sashes are vinyl clad. Not sure how aerosol paint would stick unless it's made for vinyl, or maybe use a vinyl primer. Krylon makes a primer for vinyl that's made to paint stuff like Little Tykes toys. If it works on them, I would think it would work on your sashes.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-31-2013, 11:02 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I don't handle much Andersen so admittedly I have not had the opportunity to replace an IG in one. What prevents that from being done?
www.HomeSealed.com
Old 07-31-2013, 11:59 PM   #8
You can replace the IG unit, but not the middle pane. Expect to replace the glazing beads as well.
Old 08-01-2013, 07:21 AM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
That is what I thought. It looks like a 3 panel , double pane unit to me, so I assume that the OP was referring to the center PANEL not the middle PANE of the the unit. OP, feel free to correct me if I'm wrong...
If I'm correct, I'd stand by my original recommendation of replacing the IGU. Sash replacement is a possibility as well, but it will cost more and it will likely stand out to have a shiny new sash in a faded old frame. Just my $.02
www.HomeSealed.com
Old 08-01-2013, 10:21 PM   #10
I didn't see the pic linked. That should have a double pane glass that is IIRC 3/8" thick. Assuming I am correct, the glass should be a "welded " glass, meaning there is no spacer bar. No matter what, the glass will look different since the welded glass is obsolete. A glazing company would be able to replace that.
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
Replacing Andersen windows without andersen windows. cpitcock Windows and Doors 3 08-16-2011 11:05 PM
Marvin vs. Andersen Windows GinoS Building & Construction 2 06-22-2011 10:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
buying Andersen windows charliebrown314 General DIY Discussions 14 03-14-2009 12:17 PM
