Aluminum Window Wrap Install ? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 03:14 PM   #1
Rewards Points: 150
Aluminum Window wrap install ?
A house i bought has new replacement windows and they wrapped the wood trim in coil wrap.......But its not caulked anywhere at all. Should it be? I would assume yes where it meets the windows? No between it and the siding channel? (aluminum siding)
organick is offline   Reply With Quote
Old 02-20-2012, 07:40 PM   #2
Rewards Points: 636
i personally say yes
jaydevries is offline   Reply With Quote
Old 02-20-2012, 09:49 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
if the aluminum cladding was properly installed it shouldnt need caulking on the joints other than where it butts up to the window itself.
woodworkbykirk is offline   Reply With Quote
Old 02-20-2012, 09:52 PM   #4
Rewards Points: 14,026
A picture would sure help to make sure were all talking about the same areas.
Old 02-22-2012, 07:30 PM   #5
Window and Door installer
Yes, there are extremely few reasons for this to not be caulked, at least to the window. Without knowing what is under it? Definitely yes.
Since he just purchased the house, there is no way to know if this was properly installed. Better safe than sorry.
Jkslate is offline   Reply With Quote
The Following User Says Thank You to Jkslate For This Useful Post:
Tom Struble (02-22-2012)
Old 02-22-2012, 08:13 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
A proper window wrap should rely more on proper layering than caulk, but in aluminum siding, generally you should see caulk where the wrap meets the window (on all four sides) and where it meets the siding (on the two sides but not top or bottom) assuming that they utilized the existing drip cap and did a proper bend on the sill piece.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-22-2012, 09:02 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
even when corners are turned up they still need sealant imo
now that can be placed under the seam instead of on top
Tom Struble is offline   Reply With Quote
Old 02-22-2012, 09:16 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Not sure what you are referring to... Mitered corners on the head? If so, the side pieces should extend to the top of the head piece and cut so that they wrap underneath... Not saying that caulk/sealant isn't good cya where it looks nice, but proper flashing should make it nothing more than that.
www.HomeSealed.com
Old 02-23-2012, 06:00 AM   #9
no,no face caulk
i meant where we turn up at the sill/rail connection,thats where the problem is
i actually prefer to run a hand saw blade through it as deep as possible and get the sill under it
at the sides and top i pre caulk then put a kick bend on to the unit
i agree caulk by itself will not seal long term
The Following User Says Thank You to Tom Struble For This Useful Post:
HomeSealed (02-23-2012)
Old 02-23-2012, 08:54 AM   #10
Rewards Points: 150
yes just bought the house and pretty sure homeowner did it......So caulk I will to be sure......Also a few pieces are kind bowed or warped (the piece that runs 90 degrees off the window) were they cut too tight or nailed to tight or something else? Thanks alll I appreciate the info.
Old 02-23-2012, 03:57 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 712
It hard to say by the description... A pic would be great.
www.HomeSealed.com
Old 02-23-2012, 04:01 PM   #12
MJW
Take it off and throw it in the dumpster or recycle it. That is all aluminum is good for anyhow......
MJW is offline   Reply With Quote
Aluminum siding not matching after Door install alcopaulic Building & Construction 1 09-07-2011 08:46 PM
window install on t1-11 racebum Building & Construction 3 07-19-2010 07:17 PM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 11:56 AM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 11:13 AM
