Aluminum Window Wrap - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 02:53 PM   #1
Aluminum window wrap
Is this wrap installed correctly? Shouldn't it have been installed all the way to the glass blocks?Aluminum window wrap-imag0193.jpg
lindy617 is offline   Reply With Quote
Old 09-10-2012, 09:24 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
There are several things that could have been done differently there, but yes, ideally that wrap should have gone up to the block. My initial thought is the the wrap was done prior to the glass block being installed, so they probably just wrapped up to where the former storm window was mounted on those blind stops. You could have someone come out and just put an "L" bend on those exposed stops, but it would look much better to redo the whole thing at this point.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (09-10-2012)
window vs. brick arched opening vs. aluminum flashing amakarevic Windows and Doors 10 02-04-2012 02:33 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Removing latex paint from aluminum mill finish window frame pretzels Painting 6 03-31-2011 10:39 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Correct way to install aluminum window casing? DavesHammer Remodeling 7 01-16-2008 12:39 PM
