Aluminum Window Rehab - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 02:54 PM   #1
Question
Aluminum Window rehab
I am attempting to restore the finish on some 40 year old aluminum window frames. I began by using barkeeper's friend (w oxalic acid) but that only addressed a part of the problem (the oxidation) leaving it haze covered. Then I tried AutoSol which remove oxidation and left a shine but is really pricey. I am now trying Mother's Mag & Aluminum polish which works as good (so far) as the AutoSol at about a sixth of the cost (I really haven't done the math, only guessing). I believe that both of these later two products have distillates in them.
Here is my problem, part of the windows have a pasty, yellowed substance that is on the outer part of each frame. I cannot figure out what it is. I can scrape it loose but it is really stubborn. I put a heat gun on it and it softened up quite a bit. I am thinking it is something held on by an adhesive, but the Mother's or AutoSol should cause it to loosen but they don't. Heck it vaguely looks waxy. Does anyone have any ideas? I am fearful of getting too rough with it because that would scratch the surface of the aluminum.
drdavis62 is offline   Reply With Quote
The Following User Says Thank You to drdavis62 For This Useful Post:
Hdmiller4 (07-14-2013)
Old 03-08-2013, 03:14 PM   #2
Rewards Points: 14,278
Got a picture?
The more the surface of bare aluminum is scrub the more it's going to try and oxidize to protect it's self.
Old 03-08-2013, 06:44 PM   #3
pictures of frame
you will notice the fine job done by the Mother's/AutoSol polish and the difference of the side frame pieces (pic #1 & #2 show area where I used heat gun). I should add that I am reluctant to use the heat gun too much because I am afraid that I will loosen the adhesives on the window.
Mother's Mag & Aluminum - http://tinyurl.com/beppur3
AutoSol - http://tinyurl.com/bkbfn2l
Aluminum Window rehab-100_0852.jpg   Aluminum Window rehab-100_0853.jpg   Aluminum Window rehab-100_0854.jpg
How to disassemble aluminum clad wood window sash? JohnBinSC General DIY Discussions 6 01-17-2011 05:59 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
