Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 02-25-2013, 06:11 PM   #1
Advised on new construction in lieu of Replacement
I am replacing two windows that are roughly 34x56 with one that will be about 40-45 wide. I spoke to a friend of a friend on the phone who does this for a living and he mentioned using new construction windows. He is coming by tomorrow to look and explain. does new construction windows make sense? Thanks ...excuse any typos.. Typing on train and squeezed/sandwiched between two people
Mstrlucky74 is offline   Reply With Quote
Old 02-25-2013, 06:15 PM   #2
#1 Why are you replacing the windows and not just installing replacement wondows.
#2 Why would you want to change the size of the opening. A whole lot more work and expence.
You can get windows made to exact sizes.
Old 02-25-2013, 06:39 PM   #3
We want bigger windows. We have an inline high ranch and they are too small and look funny...two small windows on the front of the house. Geez are we allowed Joe....JK....
Old 02-25-2013, 08:31 PM   #4
I always prefer new windows compared to replacrments make sure they r done right new bigger header not just cut bigger hole and install
kaschmid3 is offline   Reply With Quote
Old 02-25-2013, 08:38 PM   #5
Yup thanks. Having a problem buying just the window without the install. Looking at the Himark, Okna and softlite but most want you to seel with the install. Wish I knew of a brand that was on par as those that was a cash carry. The Simonton @ HD is install too.
Old 02-25-2013, 09:17 PM   #6
U can try local lumber store and Lowes sells Anderson windows 200 series should be fine depending on budget u can always get higher series windows
Old 02-25-2013, 09:28 PM   #7
747
registered
747's Avatar
I like new construction over replacement windows also. One reason replacement windows don't like window air conditioners. Its not bad if its a one story house and you can remove your clapboards or vinyl and know how to do finish carpentry. Now if you have central air i would go with replacement.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
Mstrlucky74 (02-25-2013)
Old 02-25-2013, 10:04 PM   #8
I thought Anderson were crap?? At least what I thought pros say. By the way, are wood better than vinyl? We have wood now and I see that Anderson has a wood line. Thanks
Old 02-25-2013, 10:06 PM   #9
Does Anderson have STC ratings? We live on a busy road
Old 02-25-2013, 10:19 PM   #10
To be honest don't know exact ratings I do most of my window installs on shore line so Anderson is best for keeping weather out so I'm not going to blow smoke up your arse and sag I know i just tried looking on line and most places said to call manufacturer for those specs. I'll try to find out
Old 02-26-2013, 05:39 AM   #11
Thanks...don't go crazy
Old 02-26-2013, 10:31 AM   #12
AHH, SPANS!!!
that is quite the project and will require new headers in the openings for the new size. plan on demo of the entire wall covering (drywall)floor to ceiling in the room the windows are in unless the headers can be added from the outside which really never happens. a trick I learned years ago is to leave as much drywall as possible on the wall up near the ceiling and still be able to put in the header. not having to mud the seam at the ceiling will save a lot of work on the project because if done right all new painting that needs doing is on the walls only and does not transfer up to the ceiling . sometimes though the drywall needs to come off up to the ceiling so...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Mstrlucky74 (02-26-2013)
Old 02-26-2013, 11:55 AM   #13
Windows & Remodeling
HomeSealed's Avatar
You can find those products cash and carry, you just might have to work hard to find them. Look up all of the dealers of those products in your area and just ask
Andersen wood windows are decent if you go the wood route (although I prefer Marvin), not a big fan of their vinyl (Silverline/American Craftsman).
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
replace replacement windows theone Windows and Doors 3 10-19-2011 10:16 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
Install replacement window while keeping new construction window in place key1cc Windows and Doors 9 03-25-2011 09:15 AM
New construction using a replacement window crewguy Building & Construction 0 02-14-2011 01:15 PM
New Construction vs replacement windows Rob461 Remodeling 2 01-23-2011 12:12 AM
