-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   adjusting a swing/tilt type garage door (http://www.diychatroom.com/f104/adjusting-swing-tilt-type-garage-door-170923/)
yhfwd05 02-03-2013 03:53 PM
Hi all,
I've got a 23' wide swing/tilt type wooden garage door from the 60's. It's nicely built and I don't want to replace it with a roll-up door. However, the door is out of adjustment and is preventing the opener from opening and closing the door without grinding against one side of the rough opening.
I haven't had much luck finding DIY's on adjusting these swing-out doors - most of the stuff online seems to be about roll-up doors and the dreaded torsion springs.
At the close position on one side, the bottom of the door comes about 1 inch from the threshold of the garage floor. One the other side, the gap is close to 3 or 4 inches.
There are solid torsion bars that go across the length of the door at the top and bottom - what are these for? Should I tighten them, loosen them? I've made sure that all nuts and bolts on both sides of the door are nice and tight. What I'm looking for is a procedure for aligning the door to the rough opening, starting from scratch.
Thanks for your help, guys.
Canarywood1 02-10-2013 03:49 PM
"There are solid torsion bars that go across the length of the door at the top and bottom - what are these for? Should I tighten them, loosen them? "
Thats where the problem lies,DO NOT attempt to adjust these yourself,time to call the pros.
