Adjusting A Sliding Glass Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 09:01 PM   #1
Question
Adjusting a Sliding Glass Door
I have a sliding glass door & it is sliding on the metal track. I know there are a couple of screws near the bottom & on either side. Turning 1 screw seemed to help (helped but not enough) & the other screw on the other side will not turn. Is it ok to spray wd-40 on it? Is that all there is to adjusting a sliding glass door?
Thanks in advance!
spark0fun is offline   Reply With Quote
Old 09-30-2013, 09:12 PM   #2
Rewards Points: 582
Thanks in advance!
I would not put any oil on your door..you should be able to adjust door by the screws on either side. those are the rollers ..could be broke may have to remove door panel...and may be installed wrong out of level and square...ben sr
Old 09-30-2013, 09:42 PM   #3
Rewards Points: 13,270
Simple enough to back the screws off and lift the panel straight up and try to pull it out at the bottom.
Often time it takes 2, people. One to lift and tip the other one using a flat screw driver to lift a little on the rollers.
Lots if times the rollers lock up, the springs get weak or break, screws strip out and need to be replaced or repaired.
spark0fun (10-01-2013)
Old 10-01-2013, 07:04 PM   #4
Thank you, that helps a lot!
Tags
door , glass door , sliding
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General DIY Discussions 12 05-02-2013 11:39 AM
placing new window in sliding glass door space L. Loving Building & Construction 1 10-25-2012 01:33 PM
How to approach a wood rotted sub floor and frame under a sliding glass door nmadigan Building & Construction 16 08-27-2012 05:48 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 09:49 PM
