Adjusting French Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 05:53 PM   #1
Lightbulb
I have recently hung outside hinged french doors. The gap in the middle where the doors close together is too wide. How do I adjust to bring the doors closer togewther and close the gap to make a tight seal?
Mikedotcom is offline   Reply With Quote
Old 09-09-2011, 08:36 PM   #2
Rewards Points: 5,336
Which manufacturer did you use?
The instructions should have explained the adjustment process, but if it's unclear, let us know.
Ron
B. Franklin 1759
Old 09-10-2011, 01:26 PM   #3
Too Short? Cut it Again!
Did these come with a new pre-hung frame around them or are you trying to use the existing door frame? Is the new frame level and square including the floor span underneath? French doors can be tricky. You sometimes have to jack up the floor joist under them to square and level the floorspan. Not trying to be insulting by the way but many forget to check for level/square along the floor and just square and level the header and sides of french doors. You would not be the first person to get french doors and new frame the wrong size for an opening either. This would leave you with a gap in the middle.
As mentioned, the instructions for a new frame and doors should have come with adjustment instructions.
Old 09-10-2011, 10:32 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Do the doors have a T strip? If not you can install one to make the gap right, I always hated installing them, you will see why if you install one.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Tags
adjusting french doors , hanging doors
French Doors Don't Meet In Middle tima2381 Building & Construction 11 03-07-2011 06:42 PM
Exterior french doors install? imola ghost Carpentry 3 11-16-2009 06:06 AM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 11:26 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
