Adding A Patio Door With Stucco Siding - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 06:36 PM   #1
Rewards Points: 91
Adding a patio door with stucco siding
Hey Gents,
Looking at the prospect of adding a patio window (and subsequent deck) where we have a 48 inch wide window currently.
Regardless of what door I pick, my biggest questions come with sealing the exterior of the door with the existing stucco. According to the lumber yard, you stick the door in your opening, nail it in, add a drip edge to the top of the door, then use the 4-5 inch wide flashing tape to seal everything to the house. Brick moulding goes over and then siding up to that.
In an ideal world, I would only have to remove enough stucco to allow for the nailing edge, drip edge, and the brick moulding. If I end up cutting back to add the tape, I will have to add back stucco. I am unfamiliar with anything but cutting and removing stucco, and finding someone who works with it has been unfruitful so far. The way I see it if you seal the brick molding to the door and seal the molding to the stucco, you should have a weather proof seal.
Getting anyone to talk to me about stucco specific options has been difficult, seems all anyone wants to talk about is lap siding and such options (that they sell of course). Does anyone have any specific experience that they can share as to how you sealed a door or window in stucco?
quackaddict is offline   Reply With Quote
Stucco over asbestos siding Maria76 Building & Construction 2 10-08-2012 08:30 PM
Stucco Installation over Aluminium siding mjlsal Remodeling 15 05-04-2011 07:50 PM
eyebrow arch on enclosed stucco patio stobin Building & Construction 2 01-31-2011 04:33 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
Mounting Hose Reel on Stucco Siding xquercus General DIY Discussions 5 07-03-2008 12:00 AM
