Abloy Front Door Lock is loose - how to open to tighten
Bingo !! Thanks Gencon !! Thanks so much for your quick reply !!!
There was indeed a small cover, which when I originally tried to "unscrew", seemed stuck....but it seems to be more of a snap-in hole cover...Once I managed to pry it out, I could easily see the recessed Allen key heads....
Now, I also have some other Abloy straight deadbolts which are Key lock ONLY on both sides... There is no visible hole to access. Are you suggesting that the outer "decorative" ring can be spun and threaded off ? I am spinning it and it doesn't seem to get any tighter or looser.....
Tks,
wayne...
