8ft Garage Doors/opener - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 07:46 AM   #1
8ft Garage doors/opener
I am looking at possibly replacing the garage doors in a new house. The doors are standard width, but they are 8ft.
The existing openers are Chamberlain BW0777 1/2 HP models.
Many of the openers I have looked at say they are only good for 7ft doors.
Is there any rule of thumb to determine if an opener is sufficient or do I have to dig up the info on each door?
Also, on some units that info is easy to find and on others it is very difficult.
Thanks!
kapeman is offline   Reply With Quote
Old 03-19-2012, 08:32 AM   #2
Rewards Points: 2,238
Hi!
"kapeman"
Usually, when they're referring to the size of a garage door -
they mean the height of the door, not the width.
7 ft. high door - 8 ft. wide - 1/2 horse power - should be OK.
rossfingal
rossfingal is offline   Reply With Quote
Old 03-19-2012, 08:43 AM   #3
Sorry! - I might have read your post too fast!
If the doors are 8 ft. high -
you should try to find an opener that is suitable.
It has to do with the length of the "rail" -
screw, chain, etc...
(Me bad!)
rossfingal
Also, remember - when choosing the hp. for an opener -
the type of door and the weight of the door should be taken into consideration.
Solid wood doors - some steel doors can be very, heavy!
Old 03-19-2012, 10:13 AM   #4
(Me bad!)
rossfingal
Thanks for the info. I am pretty sure the rail length will be the only real issue since the 1/2 HP openers are working now.
When the manufacturer states "only 7ft doors" does that mean the unit in question does not support the rail extensions?
Old 03-19-2012, 12:21 PM   #5
If you are replacing the doors -
if the existing doors are 8 ft. high and the openers work -
why replace the openers?
Unless, the new doors are substantially, heavier than the the existing doors.
Some openers support rail, extensions - some don't.
rossfingal
Old 03-19-2012, 12:26 PM   #6
Most door opener manufactures will have an extra box with a piece of rail, chain, etc for the 8' rail.
Sears, liftmaster/ chamberlain are the only brands I recommend.
I told a guy once standing in line at Menards to put the Stanley he was purchasing back....he asked why.....I pointed at my shirt...
Doorman54 is offline   Reply With Quote
Old 03-19-2012, 12:29 PM   #7
Just to clarify the doors are not being replaced just the openers (maybe). Why? They are old and the remotes and a couple of the sensors are missing. We also want an external keypad.
We are also investigating working with what we have and replacing the missing items.
Thanks again for all the responses!
Old 03-19-2012, 12:52 PM   #8
I am referring to the opener only.
Old 03-20-2012, 07:26 PM   #9
Thanks!
If you buy another chamberlain (and you should) you can reuse the current rail.
Darren R is offline   Reply With Quote
Old 03-12-2013, 08:35 AM   #10
brucewilles's Avatar
Thumbs up
Suggestion!!
Hey!! did you ever tried an automatic gates for your garage???
Just try it!! Or ask me its really very easy to install and very simple to use as its an automatic one you don't have to do anything!!!
brucewilles is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
