34 Inch Entry Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 07:59 AM   #1
bryanp22's Avatar
Rewards Points: 294
34 inch entry door
My house was built in the late 1950s and has 34" exterior doors. Anyone found a good place to buy them? I was just going to get them at home depot as I have a gift card, but at least on the website they only show one all steel and we want one with some glass at the top.
bryanp22 is offline   Reply With Quote
Old 02-28-2012, 08:34 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
HD and the like can special order whatever you want, although I'd recommend going to a buuilding supply house in your area instead. You'll probably get a better price, selection, and deal with more knowledgeable people. Thermatru makes a nice door for the price and Provia makes a great door.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-28-2012, 08:57 AM   #3
bryanp22's Avatar
Rewards Points: 294
Any rough price ranges for the brands you recommended? I'd probably just go with steel and primed door frame.
Old 02-28-2012, 09:01 AM   #4
Rewards Points: 528
hjat you are looking for is not normally a stock item.
Go to your local HD and ask, they will answer the questions for you.
framer52 is offline   Reply With Quote
Old 02-28-2012, 11:02 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
In insulated steel, primed, it all depends on the style, but I'd guess that you can find something decent for a few hundred bucks. The only way you'll find cheaper is if it was a stocking size at one of the box stores, but nobody stocks much for the 34" size.
www.HomeSealed.com
Old 02-28-2012, 11:08 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,706
All the cut down customer doors will usually come at a bit of a premium.
Certainly there is not more material in it and the cost to make it is roughly the same. Something about the "custom" tag drives up the cost from suppliers though.
Old 02-28-2012, 11:49 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I just re-read and noticed that you want to use your HD gift card. They can order you the door that you need even if they don't stock it.
www.HomeSealed.com
Problem installing entry door Jemo Building & Construction 19 09-13-2015 07:50 PM
Front Entry Door Paint/Color Advice gibear2k5 Interior Decorating 23 08-30-2010 04:52 PM
Old 80" wood entry door replacement janralix Carpentry 5 08-18-2009 12:02 PM
Problem with garage door side entry thundercloud Carpentry 6 06-09-2009 06:27 AM
