2 tall Pella casement windows that have stuck upper release.
Does the latch not move or does it move and do nothing? If it won't move, the window is more than likely stuck because of improper header construction...size, support...etc. Try gently prying up on the bottom of the window while working the latch. If you get it open you may need to do a little work on the jamb or the sash itself.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
