2 Inch Backset Deadbolt On Patio Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-14-2014, 09:39 PM   #1
2 inch backset deadbolt on patio door
New here so naturally I am looking for some help. I have an old National lock deadbolt that broke. We are not going to be replacing the patio door until next year. Unfortunately, the deadbolt had a 2 inch backset and all the options are full replacements at around $90. I am just looking for the inside bolt. Any suggestions where to look?
Pete
Sent from my LG-E980 using Tapatalk
psal217050 is offline   Reply With Quote
Old 03-15-2014, 04:56 AM   #2
Rewards Points: 16
Absolutely just call around to your local lock smithing shops. Chances are most of the houses in your area have had this same problem so the local guys keep specialty things like that around knowing it will sell.They should definitely carry what you need. Good luck!
FullSwing is offline   Reply With Quote
Old 03-15-2014, 05:35 AM   #3
Local had a substitute but at $80. Just don't want to put money into a door that will be replaced. Home Depot has a Jimmy Resistant-Entry-Door-Deadlock-U-9970 that might work as a temp solution. New here so I can't post the link. Thanks.
77/78 in screen door and heigh adjustment daluu Windows and Doors 5 03-31-2014 07:31 PM
Anyone ever installed a fresh install deadbolt on a steel hollow door? bklynsoulja Windows and Doors 3 12-28-2013 09:22 PM
Adding a patio door with stucco siding quackaddict Windows and Doors 0 12-26-2013 07:36 PM
Drafty patio door w/ pet door lambo13 Building & Construction 10 01-10-2011 06:20 PM
Replacing windows with sliding patio door, should I match widths? TomServo Building & Construction 5 09-21-2009 08:22 AM
