#1 |
1905 Casement Window Hinges Removal
I am trying to remove a hinge fitting from an old window frame. Please see picture below. I think the fitting is called a gate hinge or a blind hinge although being over 100 years old, there are not many photos on the interweb (like none!).
Hope you can help
#2 |
Exterior Construction
This site does not allow for the direct attachment of pictures but if you register a free account on photobucket or similar photo hosting site, you can link to the image and more people will be able to see it.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Average Joe/ex-Navy IC3
If you click on "Go Advanced", you will see a section labeled "Manage Attachments". From there, you can attach a .jpg, .gif, that has to be 620x280. If you link from photobucket, flicker, etc. you need to size the pictures appropriately, so that they are not so small you cannot see the detail, but not so large, that it blows out the margin.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| The Following User Says Thank You to gregzoll For This Useful Post: | Linesman (10-01-2012) |
| Display Modes | |
| Sliding Window Removal Help | AZSun | Windows and Doors | 4 | 09-07-2011 09:26 PM |
| Egress Casement Window in the basement | cmatos | Building & Construction | 3 | 09-06-2011 05:27 PM |
| How to do retrofit installation for a casement window without z-bar? | forkshen | Windows and Doors | 1 | 06-22-2011 11:02 PM |
| Need thin (14" or less wide) casement window! | jaes | Remodeling | 1 | 06-06-2010 08:07 AM |
| replace sash with casement window | fiostech | Building & Construction | 2 | 11-11-2009 05:08 PM |
