Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-29-2012, 12:46 AM   #1
yet another attic kneewall question with picture
Picture of attic kneewall for bonus room above uninsulated garage.
Located in ohio
My thoughts are to fill in the missing tyvek with reflextex and insulate..
Attachment 62678
Am i on the right track?
brianxmurray is offline   Reply With Quote
Old 12-29-2012, 01:21 AM   #2
Exterior Construction
Windows on Wash's Avatar
Better yet would be to spray foam all the gaps and back it with a ignition/thermally compliant rigid foam.
Old 12-29-2012, 01:54 AM   #3
Does it matter if the faced batt insulation already inplace has the vapor barrier facing towards the living space?
yet another attic kneewall question with picture-forumrunner_20121229_015218.jpg
Old 12-29-2012, 02:01 AM   #4
Reflectix is no less of a vapor barrier than is foil faced ISO and less than XPS.
You could cover the joist (perpendicular) with batts as well and cover with Tyvek for wind wash protection.
Old 12-29-2012, 02:28 AM   #5
Thank you for the suggestions, much appreciated. I like the foam idea but hate working with the stuff. The batt/tyvek solution seems like the best.
Thanks again
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Advice for insulating attic kneewall from unfinished side... pasichnyk Building & Construction 10 12-19-2010 08:38 PM
Attic fan question? k.kuenn HVAC 7 05-25-2009 08:05 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
