XPS on wall, and below slab
Hi All,
This weekend I'll be finishing my french drain and possibly adding 2" XPS foam, depending on what you guys tell me...
From the picture, would it be OK if I concrete beside the XPS foam? I have 7'6" ceilings so a full 8ft pc of foam will not fit and instead of cutting it, could I leave the remaining beside/under the slab? I would imagine this would help push any moisture into the drain I have below?
Basement Demo started Jan 2012: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Bathroom demo started Feb 2013: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
