XPS For Rim Joist - Insulation - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 06:35 PM   #1
Rewards Points: 77
XPS for rim joist
When using XPS foam to insulate and seal the rim joist in a basement does the foam need to be right up against the rim joist or can you seal off the cavity at any point?
Mikenra is offline   Reply With Quote
Old 03-02-2012, 06:53 PM   #2
Rewards Points: 12,818
Tight to the rim, you do not want any air space.
Old 03-02-2012, 06:55 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
That right there.
Old 03-02-2012, 07:34 PM   #4
Rewards Points: 77
That's unfortunately what I thought. With the cavity being used as a wire chase, not possible. Don't think foam is a viable option since I'd have to de rate the wires encased in it. Any thoughts?
Old 03-02-2012, 07:46 PM   #5
Rewards Points: 864
As long as it is airtight, the offset is not that bad.
Cut the foam tight to the framing and seal with foam or sealant. You will still be stopping the air loss/gain which is the bigger issue when it comes to energy loss.
If you want, stuff some rockwool in there before you put the foam back and seal it.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Mikenra (03-02-2012)
Old 03-03-2012, 02:03 PM   #6
Rewards Points: 1,092
Or, poke a hole or two in the foam board and squirt in GreatStuff or the like; good luck re-wiring in the future, though.
Old 03-04-2012, 01:34 PM   #7
Rewards Points: 864
Old 03-04-2012, 02:03 PM   #8
Yeah, some folks are just looking for the quick and dirty answer, so I thought I'd throw that one out. If the house is almost expired anyway, it may be applicable. I'd hate him/her forever if I ever had to re-wire in there, though.
Old 03-04-2012, 11:35 PM   #9
Rewards Points: 77
Nope just looking for the right answer. Think I got it. Thanks all!
Better to cut batts than scrunch them to open up space at rim joist? darlingm Insulation 2 08-30-2011 01:26 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
