XPS On Floor Sealing Questions - Insulation - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 09:56 AM   #1
XPS on floor sealing questions
Hello!
So, I've been reading a lot and I think I'm going to finish my basement floor like so:
The existing floor is 4 inch of concrete over 4 inch clean stone with perf pipe to gravity fed sump. I've never had floor moisture issues, but I also know there is no vapor barrier under the concrete.
I think I'm going to use 1/2 inch XPS under 2 layers of 1/2 inch ply (alternating directions)
I will use tyvek tape to seal the joints in the XPS (using 2 inch XPS on block walls as well)
My question is about the foam sealant. Say on the flooring where the XPS butts (or overlaps...haven't bought the stuff yet), if tight and taped, do i need to spray foam, too? If so, would I use Great Stuff or..? And where would that go. On the concrete where the pieces meet or on the top where the tape goes?
Thanks!
damon
Subliminal is offline   Reply With Quote
Old 06-08-2012, 07:44 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Why 2 layers of plywood? XPS has very good compressive strength and should be fine under a plywood deck. Might as well have 1" of foam on the floor instead of 1/2"
Use foam to seal the larger gaps (closed cell) and sealant and tap to seal all the seams.
Old 06-12-2012, 11:31 PM   #3
Registered User
Rewards Points: 526
I'd go with two layers as you said, that much better at stopping room air getting to the slab; http://www.buildingscience.com/docum...g-your-basment
The thicker foam board is recommended for colder climates; http://www.buildingfoundation.umn.ed...timum-main.htm
where are you located?
Gary
Old 06-13-2012, 06:58 AM   #4
I'm in NJ. It gets (relatively) cold in the winter...can get down in the teens, at any rate. And, of course, up to 100 in the summer.
I grew up in AK, so I know it doesn't get THAT cold. ;-)
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
