Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-17-2013, 02:09 AM   #1
Exclamation
Xps board
So I installed my 2" xps board on my basement wall and the PL-300 really took and held well. However, when I put my hand over the top of the board I can notice a slight draft coming from behind the board. Should I seal this or leave it so it can "breathe"?
If I should seal it, what should I use?
Thanks.
Mijotter is offline   Reply With Quote
Old 01-17-2013, 03:03 AM   #2
Thread killer
Xps board
Are the joist bays on the top of your basement wall insulated and air sealed? If not, the draft could be coming from there. And no, you don't want your wall to "breathe", use a can of foam and seal it up.
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 01-17-2013, 05:51 PM   #3
Xps board
Ok it is my understanding that the 2" xps board allows some breathability through the board that is slow is this correct? So I seal around the entire foam board against the concrete correct?
Old 01-17-2013, 11:38 PM   #4
Thread killer
Xps board
The warm indoor air holds more moisture in a vapour than cold outdoor air. If you don't seal the leak where you feel the air, then you could have the vapour condensing in that spot. Then you get wet. Wet is bad, especially if you insulated enough to keep most of the heat away so it can't dry out anymore.
If you're interested, you can do a search and find all the technical details about insulating you could ask for here. Just look for posts from GBR in this section, he has good links in them.
The Following 2 Users Say Thank You to Canucker For This Useful Post:
Gary in WA (01-17-2013), Mijotter (01-18-2013)
Old 01-17-2013, 11:44 PM   #5
Moderator
Xps board
No air should be allowed on the f.b./concrete joint. Air brings moisture form outside/inside (humidity). http://joneakes.com/jons-fixit-database/743 Foamboard installed air-tight to concrete will insulate and vapor retard any cold moisture coming through the concrete. If you air-seal the f.b. and glue as mentioned; with the "closed grid pattern" (horizontally and vertically) which limits the surface area of the air movement and wetness to diffuse through-- rather than drain-down to collect/pool at the bottom- possibly wetting wood framing (to mold, being organic) or cavity insulation from wicking- degrading it's R-value- if fiberglass; http://archive.nrc-cnrc.gc.ca/eng/ib...ling-heat.html
Seal the perimeter edges (canned foam) when installing against the closed-grid adhesive pattern. Mastic/tape the seams between panels, keep in mind f.b. will shrink over time (reason I typed mastic first); http://www.buildingscience.com/docum...a-foam-shrinks
Rim, as said already;
Insulating Rim Joist - caulk or spray foam around edges?
Gary
Thanks, Canucker, I was busy cut/paste my other links from other threads....!
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Tags
basement, draft, insulation, seal, xps
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Fascia board install - unlevel rafter tails giperbolic Roofing 3 01-18-2012 12:46 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Ridge board enough? runningforyou Roofing 9 08-13-2008 08:43 PM
