Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-26-2012, 03:12 AM   #1
Is it worth it to replace my exterior wall insulation?
Hello all,
Long time lurker, first time poster here.
We have a brick house that was built in 1963, and I'm gearing up for a renovation project that will combine two bedrooms and an existing bathroom into a master suite. Since I will be building new walls, and finishing drywall, I'm toying with the idea of replacing the exterior wall insulation.
It appears to me that the existing insulation is approximately 3" mineral wool batt insulation. It is black fibers that are 1/2"-3/4" in length, and the paper backing is black as well.
My question is whether or not it is worth it to replace the existing insulation with R-13 or R-15 fiberglass batts. Would the energy savings be worthwhile enough to warrant the extra work?
Thanks!
-Kiel
Optical1 is offline   Reply With Quote
Old 11-26-2012, 07:19 AM   #2
Exterior Construction
Windows on Wash's Avatar
Just replacing insulation for other insulation will not have any payback schedule unless the older insulation was improperly installed of missing in locations.
Opening up the wall and air sealing prior to insulating will have a net impact of air tightness and efficiency.
Old 11-26-2012, 03:13 PM   #3
Thanks for the quick response! I suppose I have always assumed that old rock-wool insulation is less efficient than modern fiberglass insulation at the same thickness. Thanks for saving me the added work associated with removing and replacing all that drywall/insulation. Now if I could only find a way to lower my heating bill...
Old 11-26-2012, 03:37 PM   #4
Architectural Designer
AGWhitehouse's Avatar
Look into passive solar...It can be dirt cheap and effective if your handy...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 11-26-2012, 05:05 PM   #5
+1
Air Seal and insulate as well. Keeping that heat inside the home will make it much cheaper than heating the great outdoors.
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 11:04 AM
Garage ceiling insulation worth the cost? sparks1032 Insulation 7 01-15-2012 09:34 AM
Garage insulation - to replace or not, and related questions DaveinGA Remodeling 6 12-20-2009 11:25 AM
blown in attic insulation, replace or add to Yoyizit HVAC 17 11-10-2008 09:25 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
