Is It Worth It To DIY Spray Foam Insulate? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 03:52 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by Windows on Wash View Post
What is the exterior wall made of and like?
http://www.buildingscience.com/docum...commendations/
Climate Zone 4c
Probably likely that you don't really need one if you seal up the exterior sheathing and take the ADA (Airtight Drywall Approach) on the interior.
If you have something where you be concerned about a vapor push from the exterior, might make sense to have some rigid foam at the outside wall to help mitigate that push. That being said, this can create other condensation potential if not done properly.
Gary is the psychrometric chart chart wiz.
The exterior there is plywood sheathing, and tar paper (siding coming soon). We don't really get that cold here, but we do get some wind, especially against that wall.
Journeyman Plumber
Old 04-16-2013, 07:29 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,634
Put rigid foam under the new siding and you will really improve the efficiency of that wall assembly.
Spray foam the interior of a exterior brick wall? Convict3 Insulation 13 08-21-2012 07:01 AM
spray foam question bignezzy74 Insulation 1 08-20-2012 07:14 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 10:14 AM
