#1 |
Working in Attic After Insulation Install
I am in serious need of attic insulation. I plan on putting in some blown in insulation. However, I know there will be some minor work Id like to do in the future. Is there anything that can be done before install that would make it easier to work up there afterwards?
Or is it something thatll just require moving of the insulation when the time comes, so I know where to walk and access the wiring and what not that I need to? |
#2 |
Windows & Remodeling
Get everything done before you blown in the insulation
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Moderator
I agree, and air seal first; http://www.google.com/url?sa=t&sourc...O842EQ&cad=rja
Then add some joists/plywood on top of existing joists each side of the bearing walls below for a raised catwalk above the new insulation. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Cape Cod Style House Attic/Crawl Space Insulation Help | Danielg | Insulation | 24 | 05-21-2012 09:20 AM |
| AC Flex Duct - Suspend above attic insulation or lay it on top? | fritzycat1 | HVAC | 13 | 08-17-2011 11:19 PM |
| Attic Insulation Help | charbear | Insulation | 1 | 04-29-2011 12:21 PM |
| Extending finished attic insulation stops? | Mitch H | HVAC | 2 | 12-09-2009 12:00 PM |
| attic insulation question | justin76 | General Discussion | 6 | 01-23-2008 02:28 PM |
