Window Weight Cavity - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 03:01 PM   #16
Rewards Points: 175
Originally Posted by HomeSealed View Post
The weights would not have been removed during window installation.
Please don't take this the wrong way, but it is probably better not to comment on topics if you really don't know. I have done plenty of electrical and plumbing work in my life, but you won't see me posting over in those forums because the last thing that I want to do is give someone inaccurate information or just "guess"... Just something to keep in mind.
Point taken. I should have left the window weight bit alone which is more of a window question.
Insulation, on the other hand is one of my obsessions and I stand by my first bit.
Do you know if there is any way to use a can of that spray partially and then clean it somehow to use later? I don't necessarily want to use a whole can of that per window.
I usually stuff a nail down the end of the tube then let it rest on something as it dries so the last bit of pressure doesn't pop out the nail. When I come to use it again I pull out the nail, unscrew the tube and clean it out along with the nozzle the top of the can (using a wire) and they're usually good to go.
wewantutopia is offline   Reply With Quote
Old 02-29-2012, 03:31 PM   #17
Rewards Points: 85
Where can I buy a pro gun at? I know Menard's sells the pro cans, just not the gun to spray it with.
mferguson0414 is offline   Reply With Quote
Old 02-29-2012, 03:56 PM   #18
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
Online or I have seen them at the big box stores. If not there, i.e. local, try a building supply house that sells to contractors.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (02-29-2012)
Old 02-29-2012, 04:22 PM   #19
Rewards Points: 175
Menards rules!
http://menards.com/main/paint/caulki...331-c-7937.htm
http://menards.com/main/paint/caulki...359-c-7937.htm
The Following User Says Thank You to wewantutopia For This Useful Post:
mferguson0414 (03-01-2012)
Old 02-29-2012, 04:34 PM   #20
Rewards Points: 85
I wonder where that gun is in my store. I really appreciate the links.
Old 02-29-2012, 05:31 PM   #21
Rewards Points: 175
No problem... although, I was just looking at them again, it is special order only at my store and the stores around me too. Might be the same in your area too. Could always give 'em a call and see how long to order one if it is the case.
Old 02-29-2012, 05:40 PM   #22
Tom Struble's Avatar
Rewards Points: 2,002
a siding supply house will have them
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Old 02-29-2012, 07:15 PM   #23
Home Performance
HomeSealed's Avatar
Rewards Points: 712
As Tom and WoW mentioned, a local building supply house like Allied, Alside, ABC, Norandex, Richards, etc will have them in stock. It would be a good investment for any homeowner.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-29-2012, 08:30 PM   #24
bbo
menards does sell the guns as well. the dow corning stuff some in a kit with the 2 cannisters along with a gun and various tips. I thought I was ging to go through the tips left and right. I ended up using one tip for each set I bought. I've got a bunch of tips lying around here somewhere. If you prep all the windws ahead of time and have a plan for lugging the cylinders around window to window ( there is a carrying handle ) you can probably use one tip per cannister set. The stuff is not cheap though, if you are going to do a window at a time, I'd just use the cans. closed cell is what you want for a moisture barrier.
Froth-Pak is what I used from Menards.
bbo is offline   Reply With Quote
Old 02-29-2012, 09:47 PM   #25
Home Performance
HomeSealed's Avatar
Rewards Points: 712
A froth pack at $400+ per application is way too much material for this application. Pick up a pro gun (maybe $50) and a few cans @ around $12 ea and that will do the trick.
www.HomeSealed.com
Old 02-29-2012, 09:52 PM   #26
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1 though on closed cell.
www.HomeSealed.com
Old 02-29-2012, 10:03 PM   #27
Registered User
Rewards Points: 5,516
Adding fiberglass alone is almost useless, right down the bottom of the list here:http://books.google.com/books?id=a29...995%29&f=false
The weight cavities are usually included in part of the window unit: http://chestofbooks.com/architecture...k/Windows.html
There will almost always be a rough opening framed in a wall for a window with just studs, if not studs and jack studs.
Gary
Old 03-01-2012, 07:50 AM   #28
well if the rest of the house is fiberglass,i don't see a huge problem using it in the weight pocket,i mean there's a window right next to it,what would be the advantage of ''super insulating'' that?
i would just air seal the trim to the back of the sheathing and fg the rest
Old 03-01-2012, 08:22 AM   #29
+1
Just air sealing it is going to pay huge dividends and fiberglass (while complete crap) isn't that bad if there isn't moisture or air movement.
Old 03-01-2012, 09:30 AM   #30
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I agree with WoW and Tom... I don't see where anyone suggested adding fiberglass alone.
www.HomeSealed.com
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
