Wind Flow Between Rec Room And Room Above It - Insulation - DIY Chatroom Home Improvement Forum
Old 09-18-2012, 06:58 PM   #1
Wind flow between rec room and room above it
Hi,
I was replacing the lamps of my rec room with recessed lights, and while doing that I noticed that there was a cold flow of air in the gap between the roof of the rec room and the floor of the room above it.
That might be normal...or it might not be, and that's what I'm trying to understand. I'm afraid that it is just a way for heat to escape and cold to enter into my place.
Any ideas?
Thank you.
Regards,
DavidM
DavidMoore is offline   Reply With Quote
Old 09-18-2012, 07:09 PM   #2
Rewards Points: 12,794
Your post is a little confusing. How can it be a roof if there's a room above it?
I'm guessing you mean the ceiling in the rec room.
What's the ceiling made of, sheetrock suspended?
Where the duct work run? Is it between the ceiling and the floor above?
Old 09-18-2012, 07:10 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 834
Pretty commonplace with platform framing and even worse with balloon framed homes.
Is there a cantilevered part of the home? They are notorious for being un-sealed and leaking.
Use an air tight can if you have them.
If you have a cantilevered floor, get it sealed up with rigid board and foam.
Old 09-18-2012, 07:20 PM   #4
My guess would be ballon framing if it's a really old house.
Old 09-20-2012, 07:13 AM   #5
Rewards Points: 834
+1
Balloon framed or cantilevered would be my guest.
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
Soundproofing a basement room MrAngles Insulation 5 06-06-2012 10:01 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 02:41 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
