Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-03-2012, 10:15 AM   #1
will a higher r-value equate to more sound proofing
I have just added a home theater to the basement, which is located under the living room of the first floor. Before finishing the ceiling with drywall i would like to add a layer of sound proofing to the ceiling by the means of fiberglass insulation. My question is if i use as higher r-value, with that equat to more sound proofing.
diyer111 is offline   Reply With Quote
Old 09-03-2012, 10:36 AM   #2
Will it help? Yes, will it make a big differance no.
There's better ways to do it.
Really need to add dencity to absorb the sound.
Isolation channels (Z shaped strips or metal) seperating two layers of special sound board drywall would work better.
If you Google "sound proofing ceiling" there's lots of great info explaining the science behind how to do it.
concretemasonry (09-03-2012)
Sound proofing HVAC return duct JayBird HVAC 8 07-27-2012 01:25 AM
Sound Deadening Basement Ceiling darrylshill Drywall & Plaster 4 06-01-2012 07:01 PM
sound proofing walls tiki16 Insulation 36 05-30-2012 09:53 AM
Soundproof Windows BlueJello General Discussion 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
