Will Adding Insulation To The Basement Ceiling Help Sound? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 11:45 AM   #1
Will adding insulation to the basement ceiling help sound?
I will be drywalling my basement ceiling. Would using R13 unfaced insulation be helpful in controlling sound from the upstairs? The upstairs floors are wood so you can hear quite a bit through the floor to the basement. Would using the insulation be helpful or will it not matter even with the sheetrock?
daxlw is offline   Reply With Quote
Old 03-11-2013, 12:30 PM   #2
Rewards Points: 6,652
The short answer is no. You would use decoupling clips, to hang OSB, then use Green Glue, then hang 5/8th's drywall.
Before all of that, you need to go through and get rid of any junction points that may be hidden when you hang the ceiling, proper lighting, sound proofing material around the light and outlet fixtures to stop sound transmission, etc..
There is a lot of info on this at avsforum.com.
Old 03-12-2013, 01:23 AM   #3
Rewards Points: 1,092
i think you'll find that roxul comfort batt will help a lot. it is fairly dense. This is even better: http://www.roxul.com/building+envelo...oxul+afb%C2%AE
Also, do as advised above w/ clips, etc.
Old 03-12-2013, 10:46 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,136
Insulation will help some. If you want to go full soundproofing, you will need to uncouple the structure as well.
Unfinished/Unheated Basement Ceiling Insulation mcusumano Insulation 4 08-31-2011 06:17 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Question about Insulation of unheated basement ceiling dpdolstad Building & Construction 9 03-10-2009 01:49 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
