Whistling Sliding Patio Door - Insulation - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 01:44 PM   #1
Whistling sliding patio door
My sliding patio door keeps whistling when winds are high. I don't know if it needs replacement or needs sealing. I've tried to seal it, but it didn't work. I'm ready to call the professionals.
Who does these things? I've tried calling a sliding door company, a glass company...they don't service sliding doors. So who does?
stressfreak is offline   Reply With Quote
Old 11-24-2011, 01:50 PM   #2
the Musigician
DangerMouse's Avatar
Us?
DM
Old 11-24-2011, 02:25 PM   #3
DIY staff
Rewards Points: 7,174
any idea what brand it is? wood or aluminum or plastic?
Old 11-24-2011, 02:39 PM   #4
I think it's aluminum.
Old 11-24-2011, 02:49 PM   #5
concretemasonry's Avatar
Rewards Points: 2,648
stressfreak -
I think you are facing and adjustment problem and poor seals/brushes. Not always a fixable combination, especially if it is and older or cheaper door.
I just had an old, heavy door that seemed serviceable. My new door is silent and closes tighter than the one on my freezer. It was installed by a professional from Andersen that refuses to do windows by personal preference.
Dick
concretemasonry is online now   Reply With Quote
Old 11-24-2011, 09:01 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Where are you located? In a colder climate, aluminum is a poor choice all the way around, so replacement would be advised. If you are in the south, southwest, etc, some adjustment may be all that you need.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Help: Replace bottom weather stripping on sliding patio door wakko Windows and Doors 1 08-07-2011 09:44 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 08:11 PM
Installing sliding patio door nicksr Remodeling 2 01-05-2008 09:44 PM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 07:47 AM
