What R-value Do I Have Here ? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 10:04 AM   #1
Rewards Points: 222
what R-value do i have here ?
this is what i have in my attic. just wondering, as it is going to either be replaced and/or covered with blow in. oh, those are 2x4's .
Fix'n it is offline   Reply With Quote
Old 04-22-2012, 11:00 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If that K&T is in use I don't think it can be covered with any insulation.
sublime2 is offline   Reply With Quote
Old 04-22-2012, 11:08 AM   #3
Rewards Points: 222
that is going to be replaced.
Old 04-22-2012, 11:12 AM   #4
Rewards Points: 222
oh, and, as you can see, it was covered by insulation. not saying that that is correct, but it was covered.
as to the original question. i think its about R-6, if that. and i bet that same garbage is in my walls.
Old 04-22-2012, 12:52 PM   #5
Rewards Points: 13,300
What you have is less then 1/3 of what was needed and it's upside down.
The paper was suppost to be toward the heated surface.
http://www.energystar.gov/index.cfm?...sulation_table
2X4 joist with plaster ceilings, Hmm. A sure way to have cracks everywhere.
Your going to have to make sure there's soffit vents, a ridge vent, baffles to keep the insulation away from the soffits and allow air flow.
Old 04-22-2012, 01:06 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Get the K&T out as you are.
You have about an R-6 to R-9 up there at absolute best.
Get out the K&T, air seal, blow in an R-50 and you will be so...so...so far ahead it won't even be comparable.
Old 04-22-2012, 01:13 PM   #7
Rewards Points: 222
there is paper, or whatever it is, on both sides.
there are not many cracks at all. of course it is always possible, and probably probable, that they were repaired in the past. idk
no ridge vent. there are 4 of the cheapo vents on the roof. and there are no soffit vents. though there is air leakage in those areas = i can see light leaking in. i would like to install some. but, i don't think this old house would make it easy on me. i do have a dormer on the front of the house. i was thinking about putting a slat vent in where there are windows now.
there are houses like mine that have it this way.
Old 04-22-2012, 01:22 PM   #8
Rewards Points: 222
Originally Posted by Windows on Wash View Post
+1
how thick would R-50 cellulose be ?
not only am i going to do those things. also new windows, and i am going to rip down the P&L on the outside walls and put new electrical and insulation in there.
Old 04-22-2012, 02:33 PM   #9
About 14".
The Following User Says Thank You to Windows on Wash For This Useful Post:
Fix'n it (04-22-2012)
Old 04-23-2012, 01:06 AM   #10
Rewards Points: 1,092
14.07".....
The Following User Says Thank You to jklingel For This Useful Post:
Windows on Wash (04-23-2012)
Old 04-23-2012, 08:16 AM   #11
Originally Posted by jklingel View Post
14.07".....
Well...you have about the effective R-Value of R-0.07 right now so this is certainly a step in the right direction.
