-   Insulation (http://www.diychatroom.com/f103/)
-   -   what R-value do i have here ? (http://www.diychatroom.com/f103/what-r-value-do-i-have-here-141064/)
Fix'n it 04-22-2012 10:04 AM
1 Attachment(s)
this is what i have in my attic. just wondering, as it is going to either be replaced and/or covered with blow in. oh, those are 2x4's .
sublime2 04-22-2012 11:00 AM
If that K&T is in use I don't think it can be covered with any insulation.
Fix'n it 04-22-2012 11:08 AM
that is going to be replaced.
Fix'n it 04-22-2012 11:12 AM
oh, and, as you can see, it was covered by insulation. not saying that that is correct, but it was covered.
as to the original question. i think its about R-6, if that. and i bet that same garbage is in my walls.
joecaption 04-22-2012 12:52 PM
What you have is less then 1/3 of what was needed and it's upside down.
The paper was suppost to be toward the heated surface.
http://www.energystar.gov/index.cfm?...sulation_table
2X4 joist with plaster ceilings, Hmm. A sure way to have cracks everywhere.
Your going to have to make sure there's soffit vents, a ridge vent, baffles to keep the insulation away from the soffits and allow air flow.
Windows on Wash 04-22-2012 01:06 PM
+1
Get the K&T out as you are.
You have about an R-6 to R-9 up there at absolute best.
Get out the K&T, air seal, blow in an R-50 and you will be so...so...so far ahead it won't even be comparable.
Fix'n it 04-22-2012 01:13 PM
there is paper, or whatever it is, on both sides.
there are not many cracks at all. of course it is always possible, and probably probable, that they were repaired in the past. idk
no ridge vent. there are 4 of the cheapo vents on the roof. and there are no soffit vents. though there is air leakage in those areas = i can see light leaking in. i would like to install some. but, i don't think this old house would make it easy on me. i do have a dormer on the front of the house. i was thinking about putting a slat vent in where there are windows now.
there are houses like mine that have it this way.
Fix'n it 04-22-2012 01:22 PM
Originally Posted by Windows on Wash (Post 904624)
+1
how thick would R-50 cellulose be ?
not only am i going to do those things. also new windows, and i am going to rip down the P&L on the outside walls and put new electrical and insulation in there.
Windows on Wash 04-22-2012 02:33 PM
About 14".
jklingel 04-23-2012 01:06 AM
14.07".....:laughing:
Windows on Wash 04-23-2012 08:16 AM
Well...you have about the effective R-Value of R-0.07 right now so this is certainly a step in the right direction.
:thumbup:
