What Is The Proper Way To Insulate A Cape Finished Attic. - Insulation - DIY Chatroom Home Improvement Forum
Old 03-14-2014, 12:14 PM   #1
What is the proper way to insulate a cape finished attic.
I've had 2 different home energy assesments and I'm confused! 1 Says: they'll pack the slopes with celulose, and fiberglass the rafters from inside the kneewalls down to the soffit area with NO soffit vents.
The other contracter says: insulate the rafters leaving space for baffles, fiberglass the heated walls (paper side in) insulate the kneewall floors, use soffits for ventalation. Why would they heat knee walls when they're unheated space. Why would I heat un-used space? So can someone help me out here????
Thanks,
Paul
PORT44 is offline   Reply With Quote
Old 03-14-2014, 12:31 PM   #2
The knee wall separates a finished (heated) area from an unfinished (not heated) area. So you want the paper side to be facing the heated zone.
2nd option would be the proper way to do it...you definitely want soffit vents and baffles to guide the airflow up to the ridge or gable vent.
MikeMKE is offline   Reply With Quote
Old 03-14-2014, 04:14 PM   #3
Rewards Points: 153
The insulation should be continuous from the outside wall, running along the cold side of the heated space, That means the floor joists behind the knee wall (these are celing joists for the conditioned space below), up the knee wall, then along the rafters, and across the ceiling - then same treatment on the other side.
This could be done as a hot roof, but neither proposal is doing that. If the drywall is on place already, cellulose or fiberglass insulation will be blown in. Those little baffles are flimsy, and even if they can be slid in place, I'd question whether they will crush down more or less flat when it's blown. That makes them ineffective in providing a ventilation path.
eandjsdad is offline   Reply With Quote
Old 03-14-2014, 05:28 PM   #4
The baffles would be on top of the insulation (between the roof deck and the insulation behind the finished sloped ceiling) so they would not be crushed.
Old 03-14-2014, 10:47 PM   #5
Registered User
Rewards Points: 5,482
Do you have/will ever get- soffit vents?
http://oikos.com/esb/51/sideattics.html
http://www.habitat.org/env/pdf/ceiling_and_attic.pdf
Will the second company (first one is not even in the race for your money) be air sealing the attics first? http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Location?
Gary
PS. Welcome to the forums, Paul!
Where to mount roof Attic Fan Finished Attic johndd34 HVAC 7 09-09-2013 12:33 PM
Cape cod side attic insulation problems (fun) capecodfun Building & Construction 1 01-27-2011 01:49 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Finished attic insulation and ventilation issues diyfreak Roofing/Siding 1 10-07-2008 11:01 PM
