What Is This Product Called? Still Exist? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 01:25 PM   #1
What is this product called? still exist?
20 years ago I briefly lived with a family who used a heavy duty film mounted on a shade roller over their stairway door during the winter months to prevent heat from escaping from the living area. The film was transparent but had a mirrored quality to one side. For added description, the film was noisy when moved to walk up the stairs. I'm assuming it was a radiant barrier of some sort. Do you know what it's called?
I now live in a 1962 home which has an uninsulated family room between the kitchen and the garage. I would love to add this product to the doorway between the kitchen and the family room as a temporary measure to try to stop some heat loss this winter. I could use a thermal curtain but I'd prefer the transparancey aspect of the product I'm looking for to prevent possible collisions (I have kids) and the room room needs to be accesible to get to the garage.
Any help is greatly appreciated. So far, after hours of google searches, I've only come up with clear curtains used for livestock.
C Plig is offline   Reply With Quote
Old 09-27-2012, 02:34 PM   #2
Rewards Points: 258
I think you want mylar relective insulation. Do a Google search. Lowes.com has it listed for sale. There are other sources as well.
retired guy 60 is offline   Reply With Quote
Old 09-27-2012, 07:38 PM   #3
Rewards Points: 236
why not a glass door ?
Fix'n it is offline   Reply With Quote
Old 09-27-2012, 10:52 PM   #4
Rewards Points: 181
Check Walmart in the camping section for emergency blankets. They're only a buck or 2 and are reflective Mylar.
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 09-28-2012, 07:27 AM   #5
That would be more ideal BUT the way the rooms are laid out (kitchen counter on one side and door to 1/2 bath on other, load bearing wall) it would have to be a folding door. I also don't want to make a call on a permanent change as a kitchen remodel is planned for 2013. Just want to get through the winter more comfortably.
Old 09-28-2012, 08:46 AM   #6
Rewards Points: 236
how about pic/s ?
What product to use for (temp) patching/sealing roof? daluu Roofing/Siding 4 09-18-2012 09:20 AM
warning on roofing cement product rtoni Roofing/Siding 3 09-07-2012 10:11 AM
using Lowes edge precision flooring Andy McDonald Flooring 68 03-17-2012 01:42 PM
need advice of choosing the proper roofing shingle product nc_yella Roofing/Siding 10 11-19-2008 03:49 PM
Flooring vs Subflooring or whatever it is called lifeontherun Flooring 10 07-09-2008 08:14 PM
